maxxs84
[SOLVED] Android Pay not suporte
Sat Jul 01, 2017 7:12 pm
Hi, why this phone does not support Android Pay??
Re: Android Pay not suporte
Tue Jul 11, 2017 2:09 pm
Thanks for your feedback. I will check this.
Tue Jul 11, 2017 2:20 pm
We will update a flash rom soon to fix the android pay problem.
Dirlok
Thu Jul 27, 2017 8:08 pm
When you fix the Android pay problem?
Brad
Re: Android Pay not suported
Tue Aug 01, 2017 1:19 am
I have a new BV 8000 pro.
Android pay is not supported.
This is imperative it works on my phone.
If not fixed ASAP I will be returning my hand set. :evil:
Thu Aug 03, 2017 9:18 am
We will provide an update soon to fix the android pay problem.
Have you already tried Firmware 20170718?
Fri Aug 04, 2017 9:51 am
We are getting GMS Certificate for this device in the moment. So on the next Firmware version this will be fixed.
chrisb
Fri Aug 11, 2017 9:27 am
Excellent :)
XXXRomanXXX
Wed Aug 16, 2017 3:53 pm
Обновление вышло, а Android Pay не работает
