tmsjaeger1
Root possible??
Fri Jun 30, 2017 3:04 pm
Is it possible to root the phone?
i need it because i need to block certrain networks but i wanna use roaming in other foreign networks (i live in the EU, Eu roming is now free, but non eu contries like swizerland are close)
is there another way?
cheer
Re: Root possible??
Sat Jul 01, 2017 2:54 am
We are studying this, will come back soon with solution.
tmsjaeger1
Re: Root possible??
Sun Jul 02, 2017 1:42 pm
Thank you for your help!!
however if you could manage to give us root access, this would really be the best phone out...
please considere it!!!
thanks!
dizmoduck
Re: Root possible??
Wed Jul 05, 2017 1:07 pm
We have developed an apps that automatic by rules could:
turn on/off for SIM1 or SIM2 depending on what country you are in
An alarm function that turn on/off for sim1/2 by time
But it only work on Android 4.XX
It was undocumented feature in Android 4 but from v. 5 it has been documented but apps do not have access to that feature???
Maybe Balckview can help?
