Mjolinor
Answering the phone
Fri Jun 30, 2017 10:30 am
This BV6000 has replaced a Samsung S3. On that when the phone rings you just have to slide any way you like to unlock and answer. Once answered I have 6 big buttons that allow me easily to select loudspeaker particularly when I am driving.
On the BV6000 I have to slide to the right, this is particularly hard when you are using your left hand (right hand drive car) and then I am presented with a row of really small buttons, one of which is the loudspeaker option.
More often than not I miss with the slide and am presented with a menu that I don't want because my finger slid upwards instead of sideways. At that point I usually miss the call because I am driving.
Is it possible to change this screen / buttons anywhere to make it more like my S3 was with bigger buttons?
Tomator
Re: Answering the phone
Fri Jun 30, 2017 12:15 pm
Of course, you may install one (or more) of many dialer applications available in Google Play. Some of them are free.
Please remember, that operating the phone while driving is dangerous. I really recommend to use BT radio to answer calls.
BV6000 P2 BV9500Pro
