Flash rom of BV6000s_Blackview_20170622
Fri Jun 30, 2017 7:11 am
Flash rom of BV6000s_Blackview_20170622 only for MT6737T.
https://mega.nz/#!kTxB3RyC!3FN6Cpz4D6Lj ... YWBPFEq54U
smarthousesys
Re: Flash rom of BV6000s_Blackview_20170622
Fri Jun 30, 2017 12:31 pm
Hi What problems does this release fix. Thanks
Sat Jul 01, 2017 5:53 am
To optimize the gryroscope and the touch screen.
smarthousesys
Sat Jul 01, 2017 8:19 am
Thank you for the reply
The touch screen is STILL too sensitive.
Is there an adjustment I can make in perhaps engineer mode to fix it??
Thanks
xvinny
Sat Jul 08, 2017 12:39 am
I am feeling the same thing.. The touch is too sensitive! Blackview, what is the solution?
Tue Jul 11, 2017 7:24 am
Can you please send some video for our studying?
smarthousesys
Tue Jul 11, 2017 8:27 am
Its not really possible to take a video to show the problem
It seems the problem is that the screen detects your finger just a fraction before the screen is actually touched.
Please provide a way of modifying the sensitivity.
That feature is available on many other Android phones
regards
smarthousesys
Thu Jul 13, 2017 11:21 am
I would like an answer to my question and suggestion on screen sensitivity???
Hood
Fri Jul 14, 2017 8:06 pm
I found that in glove mode the screen was far too sensitive and if you turned glove mode off then it was not sensitive enough, especially the Back, Home and Menu SoftKeys.
The solution I have found is I enabled Glove mode and then I downloaded SGS ScreenBooster.
In SGS ScreenBooster I set the first three options to minimum, the 4th option (Motion Filter) I set to 39 and last option is set to Max.
That has made the glove mode less sensitive and now the softkeys work as they should.
Hope this helps.
smarthousesys
Sat Jul 15, 2017 8:46 am
Hi
Thanks for your reply.
The more recent ROMs for the 6000s do not have glove mode any more.
- at least I could not find it.
I have tried SGS on the recent levels and cannot find a good setting.
It is a sad situation that Blackview feel no responsibility for the problem!
Users browsing this forum: Google Adsense [Bot] and 0 guests
