blik
where to buy the frame on BV5000?
Fri Dec 25, 2015 10:35 am
Changing the micro sd card, I noticed сracks around the screws in the frame. So where to buy the frame on BV5000? whether you can buy a better frame?
Re: where to buy the frame on BV5000?
Tue Dec 29, 2015 6:21 am
we have lots of re-selllers . you can google it on aliexpress ,ebay .
best regards,
Admin
