BV5000 Latest firmware download
Mon Apr 25, 2016 10:28 am
Hi ,
This is the latest firmware for BV5000.
Anyone in need can download it from the following website.
https://mega.nz/#!SklBBTRL!7vhkzPp1gsSu ... nhG3-4MjoY
Best regards,
Admin
gonye
Re: BV5000 Latest firmware download
Mon Apr 25, 2016 11:56 am
Thank you!
But what is the upgrade process?
ehquionest
Mon Apr 25, 2016 2:12 pm
Stilla Trojan in your file system. Malwares anti malwares app detect jf_QuickSearchBox.apk as a malware... Solution ?
jmoises
Mon Apr 25, 2016 5:01 pm
How do i update to this firmware?
thank you
AndiT
Mon Apr 25, 2016 7:23 pm
Is this for Android 6?
AndiT
Mon Apr 25, 2016 7:27 pm
Can anybody confirm that it works? I don't want to brick it.
Is it for Android 6?
tonijuana
Mon Apr 25, 2016 9:43 pm
Hello
By the time the update via OTA 6.0
SnuffThePunkz
Tue Apr 26, 2016 3:30 am
I do not believe this is Android 6.0, the patch notes OTA says minor updates for me.
Currently charging it (On third day of use, which is insane...) high enough that the phone will let me update it. Will report back anything of note when it's done for those curious.
Update1: Get this,
"Warning
Your system is damaged, wireless update is disabled!"
That can't be good.
Update 2: Ah, it's detected my Root and gets upset, downloading now.
Pete
Tue Apr 26, 2016 5:38 am
I have downloaded the update but am unable to install it as I don't appear to have the correct app to read the files even after unzipping the download file.
Is there a certain app you need prior to the install?
SnuffThePunkz
Tue Apr 26, 2016 5:51 am
No you either need to copy it onto the phone/sd card and do local update, or if your like me fight with it and swear for hours then cave and do the manual flash.
Link to the manual flash:
viewtopic.php?f=96&t=1027
For those curious, it works. Not broken like the last couple releases have been stated as by some users. Annoyingly wiped it back to factory, but not unexpected.
