toembal
Band 38, 39, 40 for 4G LTE
Thu Jun 29, 2017 6:00 am
Hi I live in Indonesia
is BV7000 Pro work in Band 38, 39, and 40 for 4G LTE?
Dongermon
Re: Band 38, 39, 40 for 4G LTE
Fri Jun 30, 2017 1:39 am
The BV7000 pro wiill work on the following bands;
Network:
2G:GSM:850/900/1800/1900MHZ
3G:WCDMA:900/2100MHZ
4G:B1/B3/B7/B8/B20
toembal
Fri Jun 30, 2017 2:30 am
thanks for your info .. is that 2 slot work in 4G or only main slot?
Dongermon
Fri Jun 30, 2017 4:27 pm
I'm not too sure, it may be both or only slot 1
Sat Jul 01, 2017 3:03 am
There are 2 slot for sim cards, one for 2G, and another for 4G.
Derk
Sat Jul 01, 2017 4:11 am
XL and Telkomsel also support Band 3 and 8.
So not usable for Bolt and Smartfen but if you are limited by hardware...
I'm using XL as where I live they have the better signal.
