Remmie63
Phone freezes
Wed Jun 28, 2017 5:36 pm
Hi, my phone freezes with error message:"Process system does not respond". On the background f.i. apps keep coming in, but can't open them. When i double push the on/off button the camera starts up but no photo's can be taken. The error message stays on top. Can't restart the phone.
I had some problem for a week when starting the phone from standby. It took about 1/2 a minute to start up.
Hope for a solution.
Regards, Remco
Re: Phone freezes
Thu Jun 29, 2017 7:47 am
try a factory reset in recovery mode (will also delete your data/settings!):
- Press Power and Volume up together for around 10 Seconds
- Then the open android with red triangle is shown press Power and Volume up together again
iMacOSX
Re: Phone freezes
Sat Jul 01, 2017 6:04 am
This not work:/
Re: Phone freezes
Mon Jul 03, 2017 3:11 am
iMacOSX wrote:
This not work:/
Re-flash using sp flash tool as it will perform a "clean" flash of the rom.
