Dretne
Rintone
Thu Dec 24, 2015 10:56 am
Hi
Is there a way for change the ringtones of each SIM?
Thx!
Re: Rintone
Fri Dec 25, 2015 5:54 am
Hi ,
The ringtone of each simcard ?
Dretne
Re: Rintone
Fri Dec 25, 2015 7:12 am
Hello
Yes, is there the opportunity for different ringtones for de 2 simcards?
1 simcard is for work en the ohter for Private. If i can have different ringtones for each card than i can hear on the sound if its work calling or Private!
Thank for your reply!!
Greetz Luc
Dretne
Re: Rintone
Fri Dec 25, 2015 2:34 pm
Hello
Yes , when i have a call on sim1 ( Work ) would be different dan when i have a call on sim2 ( Private ).
That i can hear it by the different ringtone if its Work or private
I also noticed that when i have tem a name ( sim 1 & 2 ) , after a reboot are the names gone...
And thanks for the reply!!
Grtz Luc
Dretne
Re: Rintone
Fri Dec 25, 2015 2:49 pm
Hello
Yes indeed, when i have a call to Sim1 ( Work ) i have a ohter than Sim2 ( Private )
I also noticed than when i give a name to the simcards they are gone after a reboot....
Thanks for the reply!
Grtz en Christmas wishes !
Luc
Re: Rintone
Tue Dec 29, 2015 6:16 am
Dretne wrote:
Hello
Luc
Hi ,
so sorry to tell you that different ringtone for two sim card is impossible, but you can set different ringtones for different people
Best regards,
Admin
