Blackview will release R7 in 2016
Thu Dec 24, 2015 10:16 am
Blackview R7 will come to public in 2016
1.Blackview has been aiming to provide customers with a high-end and cost-effective smartphone.
In early 2016, we will cooperate with MEDINTEK to launch a new flagship model, Blackview R7.
2 With eight A53 processors, R7 adopts P10 Helio (MT6755) chip, in which case Octa-core 64 bit
Cortex-A53 processor of 2GHz main frequency, and a dual-core 64 bit Mali-T860 graphics processor
of 700MHz main frequency, making download rate increase to 300Mbps.
3.R7 also has excellent multimedia capabilities. Except advanced display , super camera and
hifi sound, many other features, such as good image sensor, noise reduction design , intelligent color
engine and so on are also available . Such a good specification will do help it to be the leader in the
main market of smartphone.
4. Equipped with a 5.5 inch 1920*1080 2.5D LG touch-screen. MT6755 chip can support 21.0MP
pixels and 1080P LCD.
5.MT6755 Chip in R7 can support 21MPpixel as the highest. 13.0MP rear camera and 5.0MP
front camera is achieved.The front camera uses OV5648 chip, making shooting more clearly.
And Samsung's 3M2 chip is used for the rear camera. Then the shortest focus time can be just 0.3 seconds,
which is twice faster than some major mobile phones. Chip of this kind is very hot in Samsung 13M field .
The perfect SWDR technology ( smart wide dynamic range) gives R7 the best back lighted shooting
function in smartphone industry.Meanwhile, Great SNR (signal to noise ratio) increase helps R7 also
to get the greatest night shot effect in nowadays smartphone field.
6.MT6755 low-power consumption sensor will reduce the power consumption by 30%,
making video play much smoother
7. Quick charge
2.5A 9V design endows R7 the ability to reach quicker and safer charge.
90 minutes calls can be supported by just 5 minutes charge.
8. 4 GB large memory and a Octa-Core processor help R7 to run faster.
Extended 32GB local store memory and 128GB scalable memory are also
available for you to store more photos, videos and songs you love .
9.CNC box
R7 whole metal frame comes from 169 process, including eight times precise CNC machining,
Micron-sized sand blasting , vacuum-coating paint and nano anti-fingerprint technology .
10. Quick fingerprinting system is also equipped. Touch type fingerprinting of 360 degrees can be enjoyed with R7 .
Thus no need to keep the screen staying on, but just Gentle finger touch can immediately unlock the Phone in just 0.4 seconds.
11. The latest "Marshmallow " Android 6 system is also adopted. The whole new system remains flat Material Design style. User experience and software performance will be optimized with this new system. And Android 6.0 system can prolong R7 Standby time by 30%.
