zana007
Charge problem
Wed Jun 28, 2017 7:49 am
I have a BV6000, bought in december 2016.
It is not charging anymore.
I use different usb cables dedicated to my BV6000. But the problem is still the same.
These cables are working on other cellphone.
I am in France, so please tell me how i can have a new USB module for my BV6000 or how you can fix it.
Best regards,
Re: Charge problem
Wed Jun 28, 2017 10:02 am
Be sure you used an original blackview cable with long connection part.
Maybe also try an software update+ factory reset.
If it don't help you could buy an usb module (for example on aliexpress) or ask your seller for helping with this.
YAIR
Re: Charge problem
Sat Jul 01, 2017 3:35 pm
Good morning, zana007, you could solve your problem, I thank you for sharing your experience.
Thank you
