karera
Alternative Headset/Earphone
Tue Jun 27, 2017 4:15 pm
Is there any alternative headset/earphone or where can I buy a compatible headset/earphone for Blackview BV7000 PRO?
Holefighter
Re: Alternative Headset/Earphone
Tue Jun 27, 2017 5:29 pm
My samsung earphones fit if i press it in. But you can cut a little plastic off from every earphone so it will fit.
I do it with my normal USB c cable. No problems with it
karera
Tue Jun 27, 2017 5:50 pm
Ok, thanks. I'll try it.
