d.suratman
After update, screen blinks
Tue Jun 27, 2017 3:02 pm
Hello..
I have problem with bv7000 pro
After update to build BV7000_PRO_Blackview_20170523, the screen blinks /flicker
Can anyone help me..
Re: After update, screen blinks
Wed Jun 28, 2017 10:31 am
first try a factory reset. I it don't help you can update/flash the newer 20170622.
If that will not help it could also be an hardware issue. You could ask your seller for help in that case.
Timmy96
Sat Jul 01, 2017 4:05 pm
I experience the same thing...
The screen flicker, sometimes in camera, in gallery, sometimes in home screen.
Almost like an lcd broke down... But I am sure it's not a hw problem, because if I switch to app like WhatsApp, it not flickering anymore.
I am using the 20170523 version I have check the wireless update. It says my Software is currently up to date.... Pls help..
Bluescorpie
Mon Jul 03, 2017 11:05 pm
I have same issue with 20170523, i have factory reset but this still happen..
The seller cannot help me
Please @blackview admin help me
Tue Jul 04, 2017 2:15 am
Try updating to the latest rom.
d.suratman
Tue Jul 04, 2017 6:08 am
Install screen filter.apk
This app can help reduce problem screen flicker on my bv7000 pro.
I cant flash the latest rom or upgrade to 7.0, cause i dont have skill to try. Reseller/online shop on my country IDN cant respon. Maybe this way, to solve my problem.
I stll wait, if anyone hve other ways to solve this problem.
jmsupery
Tue Jul 04, 2017 12:33 pm
I have also this problem as you have
Bluescorpie
Tue Jul 04, 2017 1:38 pm
I have update to last rom android 7, still have the issue,
Still blinking
Tue Jul 04, 2017 2:07 pm
can you please make a video to help us to investigate this issue?
d.suratman
Tue Jul 04, 2017 4:51 pm
This video show th issue
https://youtu.be/odtb6LmLUy8
Users browsing this forum: No registered users and 12 guests
