  • 1
  • 2
  • 3
  • 4
  • 5
  • 11
Flash ROM of BV7000_PRO_Blackview_20170622 to upgrade 7.0 OS
Mon Jun 26, 2017 8:04 am
https://mega.nz/#!MeAzgJjS!0uYktS3adpF6 ... G8hvnaMIh8
flashing-BV7000pro.pdf
(364.59 KiB) Downloaded 7978 times
Video tutorial:
https://www.youtube.com/watch?v=r9HXJH0H43oc
kup0
Re: Flash ROM of BV7000_PRO_Blackview_20170622 to upgrade 7.0 OS
Mon Jun 26, 2017 8:06 am
Finally! No we have to wait if someone is brave enough to test it ;)
Holefighter
Mon Jun 26, 2017 8:26 am
https://mega.nz/#!NDoiCYIC!VKw9EYXTY7_W ... _T7nIAfFh4
Is it test to any issues? Because i want to flash it but its my Main phone and i need it so i hope everything OS OK with this Rom?
Holefighter
Mon Jun 26, 2017 10:01 am
Guys, i want to wait, to be safe that i have no heavy issues in the rom, but what should i say... i cant wait and already installed it.
And i cant say anythin bad until now...
In this Version its google certified!
It reacts quick
and when i charge it its faster than android 6.
When i restart/start my phone its now faster.
And we have a new start animation with sound, i hope we an disable the sound maybe?
i test more and will let you know.
kup0
Mon Jun 26, 2017 10:08 am
It reacts quick
Sounds good. Does Bank apps work (Google Pay etc.)?
Holefighter
Mon Jun 26, 2017 10:21 am
My bankingapp (sparkasse/ a german banking app) runs without any problems
i just try Samsung Smart Home wich was a problem in the last versions, and ......tada :-) it works fine!
The cameraapp also get new features and a modern look!
Holefighter
Mon Jun 26, 2017 11:11 am
Obviously, the battery life was also significantly improved.
I still have 70% and the remaining time is displayed with 18 hours. I will check it
geotex
Mon Jun 26, 2017 11:23 am
Holefigther, you are the best. How do you make upgrade? By SP Flah?
Holefighter
Mon Jun 26, 2017 11:26 am
Yes, via spflash, i used the instructions in this post from blackview_admin. this works fine.
Holefighter
Mon Jun 26, 2017 12:14 pm
Is it safe, in this major version update, to exclude the userdata when flashing in order to save user app and data ?
From the "Flash Manual"
You can uncheck “userdata” so your data and setting may not be deleted.
 But if you flash for bug fixing you should keep this checked.
Could you explain better the sentence above and give us, if you can, additional suggestions ?
In other words, which is the risk if I decide to keep / save userdata?
Thanks
I keep my userdata and everything is fine...
  • 1
  • 2
  • 3
  • 4
  • 5
  • 11
