PietK
Experience with June BV7000 version
Sat Jun 24, 2017 7:40 pm
did anybody flash the new version 201706012? If yes: experience / bugs resolved?
Until today the BV2000 version 20170502 runs perfect and no glitches detected thus happy with the intial version until now: all hardware running and when switching WIFI / GSM / GPS off in power saving mode, the battery will run at l;east 1 week in standby.
Re: Experience with June BV7000 version
Mon Jun 26, 2017 5:47 am
What about the bugs in BV7000?
PietK
Mon Jun 26, 2017 4:04 pm
@Blackview-admin: as said, i personally did not notice any bugs and thus wondering what had been changed. Will install update this week and report.
olegsht
Wed Jun 28, 2017 11:49 am
Just finished flashing the phone with latest Android 7 (i didn't check the option of save userdata, so I'm re-installing and re-configuring all apps).
The issues are:
I can't find how I can change the display view to the classic (with apps menu button ) and how can I change display animation?
Wed Jun 28, 2017 1:37 pm
The issues are:
- The Android 7 launcher of bv7000 don't support that app menu but feel free to install an other launcher.
- It is not possible to easily remove the start animation/sound in the moment.
olegsht
Wed Jun 28, 2017 2:31 pm
Thanks for a quick reply!
Can you please recommend me a steady and well tested launcher?
And how can I change a home screen transition animations?
- It is not possible to easily remove the start animation/sound in the moment.[/quote]
Thu Jun 29, 2017 8:08 am
You could try CM trebuchet launcher: http://www.apkmirror.com/apk/cyanogenmo ... -download/
And I am not sure which aniation you are talking about but some you can also disable in the new launcher.
olegsht
Tue Jul 04, 2017 8:20 am
Almost week after update to Android 7.
New issue:
During the call sometimes phones screen became black(I still can speak and hear) and I cant disconnect the call or use any phone features untill the second side will drop the call.
What can I do?
Thanks!
Tue Jul 04, 2017 4:35 pm
New issue:
What can I do?
Thanks!
You can try to recalibrate the Proximity sensor:
you can calibrate in engineer mode.
- type *#9646633# into the keypad of the phone app
- go to tab "Hardware Testing"
- open "sensor > Light proximity sensor > PS Calibration > Calibration > do calibration"
dqtas
Mon Aug 28, 2017 10:00 am
I am very satisfied with BV7000 pro.
Everything works fine since June 14 that it came to my hands.
I installed Android 7 rom and the update of June.
I think that the update made the phone a bit slower, than
the original first version of 7.
Anyway I am expecting upcoming updates.
I hope they will make it faster.
