Flash ROM of P2_blackview_201706200934 to upgrade Android 7.0
Fri Jun 23, 2017 2:30 am
Flash ROM of P2_blackview_201706200934 to upgrade Android 7.0.
https://mega.nz/#!sShVAZCQ!G9nql5DHd5_r ... AUeC7PXOt4
blackview flash guide.docx
(368 KiB) Downloaded 4111 times
peter shelton
Re: Flash ROM of P2_blackview_201706200934 to upgrade Android 7.0
Fri Jun 23, 2017 7:32 am
i have followed it to the letter but when i plug phone in at the end nothing is happening is there something i need to press like start i have a windows 10 pc thankyou :roll:
Bernie_W
Fri Jun 23, 2017 8:27 am
Thank You so much. That is so great from you.
Edit: Installed it already, works perfect for me. Only wish that national roaming would work. Thanks again.
One little bug is that the MAC address changes on every restart of the phone. I'll try to correct it by changing the NVRAM. Let you know, when I find out.
rezabogeyman2028
Fri Jun 23, 2017 8:42 pm
flash it to my p2 phone
every thing works well
but fingerprint reaction is too slow.lower than android 6
rezabogeyman2028
Sat Jun 24, 2017 7:04 am
hi
What about fingerprint?
fp recognize well.but screen is slow to wake on this version.Right?
rezabogeyman2028
plz accept my comment
overnom
Mon Jun 26, 2017 6:10 am
I agree with those comments. Everything seems fine except finger scanner reacting slower than android 6 version. One more thing.. It seems 4g signal become weaker than before for some reason.
Mon Jun 26, 2017 8:05 pm
hello
there is 3 days that i have installed the new rom i confirm that the battery is too long.but the apps stopped themselve and the phone freeze.
in the day i should light off the phone with the button power anytime because impossible to light off
problem with internet connection but i don't confirm maybe the operator?
i don't understand why with the phone i can't do facebook live
thank you for the developpor to resolve the issue and their work i utilise the last version of android 6
Bernie_W
Mon Jun 26, 2017 9:13 pm
hi
Yes, that is a common Nougat 7.0 issue (maybe Dalvik cache or new doze mode?). You can try to reduce the Animator duration scale in the developer options to 0,5 instead of 1. Could help. Otherwise Nougat 7.1.2 is way better.
MermaidBlue
Sat Jul 01, 2017 2:08 pm
does it take long to update ?
