vita
Automatically downloaded apps into fresh bv2000s
Thu Apr 21, 2016 3:28 pm
I have a fresh purchased BV2000S. After connecting to WIFI, within 24 hours, I found that app SUPERB CLEANER was automatically downloaded and installed. After waking up from standby mode, I see on the screen an invitation to install FACE BOOK app. I found a couple of. apk in the Android/data/.public/download directory.
The name of the SUPERB CLEANER app begins with: d3bb7229aef943b99d7....
My question: Is this situation normal? If yes, how many apps are offered in such a way? Where can I find a list of official apps included in the distribution:
BV2000s_B2_Blackview_V0.8_20160113
Thanks.
Re: Automatically downloaded apps into fresh bv2000s
Fri Apr 22, 2016 6:40 am
you can try to solve the problem by close the unknown source option in safety board of setting.
Best regards,
Admin
