PietK
C-type USB charging
Tue Jun 20, 2017 9:55 am
Would it not be great if Blackview would offer an C-type magnetic adapter for charging the phone?
Idea when NOT using the IP68 rating (submersable) in house etc.:
- rubber USB-cover removable (fixed by screw, but current connection could be cut as well)
- design a C-type USB magnetic insert with power connection only
- use magnetic USB-cable compatible with the many megnetic connector cables as offered on aliexpress.
Standard version will not fit Blackview as too thick / short e.g.
https://www.aliexpress.com/item/New-hig ... 63622.html
maybe this one fits.
Hope Blackview will consider this on short term basis!
Re: C-type USB charging
Mon Jul 31, 2017 1:50 pm
thanks for your suggestion!
