JesSyd
No charging and no flash
Mon Jun 19, 2017 11:47 am
152/5000
My BV6000 does not accept charging and I have no flash / lamp so where can I send my BV6000 for the correct service / repair. I live in Sweden.
Re: No charging and no flash
Tue Jun 20, 2017 7:45 am
Please try to flash your phone with the download flash rom BV6000_Blackview_V01_20170517
https://mega.nz/#!ZbhE2bJS!GwxZGnTsqYfy ... DZXOlxjSAk
flashing-BV6000.pdf
(363.07 KiB) Downloaded 290 times
And after flashing, do the factory reset, below is the way of factory reset.
"Start the phone into recovery:
- Press Power and Volume up together for around 10 Seconds
- When the open android is shown press Power and Volume up together again
- After factory reset select ""reboot system now"""
If still can not fix your problem, you can contact at dimitri@d-sign.be.
