Lech
Android System Crash
Mon Jun 19, 2017 11:03 am
Hi Blackview Team! I got a problem with my BV7000 Pro. I saw a comunicate:
"android.process.acore has stopped" on my screen. After that anothers application started shutting down.
I shutted down my BV7000 Pro, and tried to turn it on. BV is showing only Blackview logo, and nothing else.
I need help. Tell me what to do, please.
Re: Android System Crash
Mon Jun 19, 2017 11:47 am
Start the phone into recovery:
- Press Power and Volume up together for around 10 Seconds
- Then the open android is shown press Power and Volume up together again
- (Maybe backup your Data to SD-Card)
Lech
Mon Jun 19, 2017 12:09 pm
Than you for quick answer. I followed your suggestion. After I choosed recovery mode I saw opened android, but it has got red triangle with exclamation mark. I could not do anything with that. Any idea what should i do?
Mon Jun 19, 2017 1:09 pm
"Then the open android (and red triangle) is shown - press Power and Volume up together again"
Lech
Mon Jun 19, 2017 1:37 pm
Menu with recovery, fast boot and normal mode apeared again and nothing else. I solved problem in diferent way.
viewtopic.php?f=176&t=141026&p=335187&hilit=flash#p335187
After fifth time of flashing problem disapeared. I think it was the only way to rescue my BV.
Thank you for this tutorial.
Don't hurry with Android 7. Do it well, not fast. We will wait ;)
Gemini
Tue Jun 20, 2017 12:10 pm
Or you could provide a better recovery, like TWRP, instead of the crappy stock one.
Thu Jun 22, 2017 12:07 pm
Thanks for your feedback how you have solved it!
Users browsing this forum: No registered users and 10 guests
