So looking for a replacement, but I can't see if the bv7000 pro has NFC. Or is it just the lower spec bv7000?
And does the bv7000 /pro need special longer USB plugs like the bv6000 did? Does it rely on rubber plugs for its IP rating?
Mon Jun 19, 2017 12:57 am
