jollen
Wanted - Instructions how to change display
Sun Jun 18, 2017 10:13 pm
Can someone please make a short instruction how to change the display on the P2 and P2 lite (guess it's the same way). I have searched everywhere but can't find any. My phone was delivered with a broken display and I can't use it until it's changed.
Dongermon
Re: Wanted - Instructions how to change display
Sun Jun 18, 2017 11:16 pm
jollen wrote:
until i get my replacement screen i cannot confirm how to do it, but i suspect using a heat gun to heat the glue and separate display from main chassis.
this is my assumption based on images found on 4pda, i have attached an image from 4pda to show you.
jollen
Mon Jun 19, 2017 12:56 pm
Thank you!
It would be very nice if you update when you get your screen.
I managed to open the phone with only my hands but I could not get the screen of without a heat gun.
Do you know if I can use a hair blower instead of heat gun?
Dongermon
Tue Jun 20, 2017 1:36 am
jollen wrote:
Thank you!
yes a hair dryer will work just as well, make sure to keep it on low heat and low speed to prevent damage to the boards and cameras
jollen
Wed Jun 21, 2017 7:32 am
Thanks!
When will you get your display?
