japi
no vibration, when the phone rings
Sun Jun 18, 2017 9:24 am
I have a litle problem: when the phone is ringing there is no vibration, regardless of whether the space is normal or outdoor. If I choose a space with only vibration, the vibration is very weak.
Re: no vibration, when the phone rings
Mon Jun 19, 2017 10:48 am
Please check if you have activated "Settings > sound > also vibrate for calls". If it's activated but the phone don't vibrate you can try a factory reset or software update.
japi
Tue Jun 20, 2017 2:24 pm
the vibrate is activated. How can I do the factory reset or software update?
Wed Jun 21, 2017 7:50 am
Software update: "settings>about phone>wireless Update>check for updates" Newest version today is 20170523
Firmware reset (will delete all your data!):
- Start the phone into recovery: Press Power and Volume up together for around 10 Seconds
- When the opened android figure and red triangle is shown press Power and Volume up together again
- (Maybe backup your Data to SD-Card)
Please report if that solved your problem.
geotex
Wed Jun 21, 2017 8:08 am
What wireless update??You have a problem with this. Don't putt the customers in wrong direction!
Wed Jun 21, 2017 10:25 am
Not all devices have a problem with wireless update.
If it don't work for you, you can also perform local file update or flash over PC.
geotex
Wed Jun 21, 2017 11:43 am
Then I understand that my phone is in trouble.I think all the BV7000Pro phones in the first series have problems.If I look at the forum, by far the one dedicated to the BV7000Pro is with the most technical problems encountered in a short time. Honest on Blackview's side is to replace the phones from the first release with those in the second series, with Android 7.0, at no additional cost. I have encountered all the problems reported on the forum, from the proximity sensor to the loss of connection (except the power supply, but it is not known if it will not appear) The impression left is that of a phone made in the garage, with software made in mockery . In my country, I paid $ 365 for the phone only to qualify for the warranty. The support is on the ground, the hardware the same. It's the first forum I've seen showing you how to dismount the phone. Seriously??
japi
Wed Jun 21, 2017 8:35 pm
Thanks it helped. Now the vibration works, but I think it could be stronger. Is it possible to adjust it?
Thu Jun 22, 2017 10:26 am
NOT ALL first BV7000 have problems and ALL will be able to flash to Android 7. No one is forced to open their phone but for those who prefer to do it instead of sending their phone around the world we like to give the best help and show all possibilities.
Thu Jun 22, 2017 10:34 am
Sorry, I don't know a way to adjust the vibration to be stronger.
