robert
Ricever problem
Sun Jun 18, 2017 8:52 am
hello ,i have a problem
1-st day i by it and conect it to the network, need it to update it....after that the ricever not working any more
befor update the ricever it workt
what i havbe to doo
Re: Ricever problem
Wed Jun 21, 2017 6:01 am
Which rom version you have flashed?
Try to reflash the phone again and do the factory reset as below:
"Start the phone into recovery:
- Press Power and Volume up together for around 10 Seconds
- When the open android is shown press Power and Volume up together again
- After factory reset select ""reboot system now"""
If still can not fix your problem, please let us know.
robert
Re: Ricever problem
Mon Jun 26, 2017 7:16 pm
ok ,i will try
