andreareda
Damage after diving in water
Sun Jun 18, 2017 7:40 am
Good morning, admin. Yesterday, after an immersion in water, althoug all the caps and the sim cover are correctly installed, the water come in my phone. the phone was TURNED on, at the moment, and since then it continue to show the writing "blackview" on the screen for some seconds and turn off. What can I do?
I live in Italy.
Andrea
Re: Damage after diving in water
Sun Jun 18, 2017 5:43 pm
Ciao,hai comprato su amazon?.....o eBay?
Andrea
Sun Jun 18, 2017 5:48 pm
Se hai comprato su amazon fai la procedura di reso e ti rimborsano i soldi...entro 2anni....con eBay non so....e comunque prova a lasciarlo al sole,magari togli il coperchio dietro e non lo esporre dal posteriore..
Con il display verso l'alto....se anche c'è acqua asciuga e torna a funzionare...se non lo apri si forma la condensa e prima che asciuga......
Mjolinor
Sun Jun 18, 2017 9:44 pm
Turn it off now. Take it apart or at least open all the covers and remove the SIM cover then place it somewhere warm and, if you are so inclined stick it in a bag of rice for at least two days.
The longer you leave it the less likely it is to ever work again and it may already be too late.
andreareda
Mon Jun 19, 2017 7:26 am
Ciao. Acquistato su Amazon (dal marketplace), ma in realtà non l'ho acquistato io, bensì un amico... :-(
Sai com'è la procedura? In ogni caso provo ad aprirlo oggi. leggevo anche di scollegare la batteria e pulire i contatti con l'alcool...
Parcheval
Mon Jun 19, 2017 7:30 am
Have a look at the workaround indicated here: viewtopic.php?f=142&t=126016
andreareda
Mon Jun 19, 2017 7:31 am
Thank you Mjolinor. I try today (I have not the right screwdrivers at my home). i want to open the phone, disconnect the battery and then clean the contacts with alcool and let it dry... do you think it could be a good idea? thanks!
Tomator
Thu Jun 22, 2017 2:49 pm
Yes, washing with alcohol can clean the electronics of any residues that the water might have left. They may cause short circuits or parasite currents which will affect the phone functions.
BV6000 P2 BV9500Pro
Alain 76
Mon Jul 03, 2017 1:07 pm
Hello, yesterday I went to the pool with my blackview Bv6000 for
2 hours to take my children in photo, I put a cache on the speaker
for security and today it still works very well.
