PRASANTH
no fast charge
Sat Jun 17, 2017 4:33 pm
it is not getting charged at fast pace.It takes around 3 hours for full charge..
Re: no fast charge
Thu Jun 22, 2017 12:09 pm
Please be sure to use the original plug and cable and use the latest Firmware 20170517.
Holefighter
Re: no fast charge
Thu Jun 22, 2017 3:20 pm
I habe the same issue i habe the latest Firmware and the original cable and adaptr it takes around 3hours
Re: no fast charge
Fri Jun 23, 2017 12:00 pm
Did you have always the same issue with all ROM versions?
Holefighter
Re: no fast charge
Fri Jun 23, 2017 3:08 pm
Yes but only if three hours is too mich. Maybe its normal.?
pellet
Re: no fast charge
Fri Jun 23, 2017 4:10 pm
With the original ROM, my BV7000 pro takes more than 8 hours from empty to full charge. I'm going to update, can't wait any longer for Android 7.0
Dongermon
Re: no fast charge
Sat Jun 24, 2017 12:57 am
are you using the provided plug?
JJonn
Re: no fast charge
Sat Jun 24, 2017 3:29 am
Seems right to me. 3500mAh / 3hr = 1166mA. The charger claims 2000mA, so it seems a bit slow, but if you factor in that the battery probably has more capacity than specs (mine measures at 4300mAh), the phone uses some current when idle (depends on your battery optimization, maybe 100mA), and you are likely exaggerating the 3hr (lets say 2.5hr). That gives you 4300mAh / 2.5hr = 1720mA + 100mA = 1820mA, pretty close to the charger spec of 2A.
grAwp
Re: no fast charge
Mon Jun 26, 2017 9:04 am
Try to buy a new charger and test it. I have 2 same original Blackview chargers but one of them charging at 17%/hour and another 50%/hour.
