pascalriou
bv6000 loudspeaker do not work!!!!
Fri Jun 16, 2017 11:46 pm
Hello, I have a problem with my smartphone bv6000 which does not produce more sound (ringing, music on the loudspeaker…), smartphone is my third blackview and I am very disappointed. what to make?
Re: bv6000 loudspeaker do not work!!!!
Tue Jun 20, 2017 7:50 am
"To enter the engineers code go to phone and dial pad and enter the code.
*#9646633#
You are now in engineer mode with the top tab telephony.
swipe across until you get to hardware testing.
select audio
select volume
select voice
you will see the drop down menu for receiver, hac, headset, speaker.
select either receiver or speaker
manually change UL gain to say 240.
scroll down the screen and hit the button Set.
go back using < key.
then select voice again just to check the setting for UL gain has changed
then press home and test by ringing someone or receiving a call."
Video tutorial.
https://www.youtube.com/watch?v=nudrlosR2fg
If still can not fix your problem, you can contact at dimitri@d-sign.be
