Jyothiraj
Issue on Calls with microphone
Fri Jun 16, 2017 8:12 am
Dear Admin , i saw peoples also talking same issue here, you told to some one its hardware problem.my P2 lite also not working microphone, if a contact the re seller , shall i get rectified new one for this ???
you told me its hardware problem, only for china make or all....., Its not seller's mistake, its a manufacturing mistake, try to resolve,
mention me if you cant resolve with software ,otherwise i want return the phone.........
Re: Issue on Calls with microphone
Wed Jun 21, 2017 6:03 am
"Start the phone into recovery:
- Press Power and Volume up together for around 10 Seconds
- When the open android is shown press Power and Volume up together again
- After factory reset select ""reboot system now"""
jyothiraj vb
Sat Jun 24, 2017 11:22 am
No change , problem not cleared, same as previous
jyothiraj , india
Thu Jun 29, 2017 5:40 am
jyothiraj , india
Please contact the online re-seller to get this solved.
jyothiraj vb
Fri Jun 30, 2017 6:11 am
i was purchased from aliexpress, they asked evidence, given some videos of microphone defect but they told me that evidence are invalid , they can't take return., i sure its operating system problem try to resolve the software and give a updates. thank you
Wed Aug 02, 2017 11:09 am
Please update to the latest firmware. that should solve the issue.
Fri Aug 04, 2017 9:28 am
If you are affected by this issue of changed microphones connection please try to update to the latest firmware and perform a factory reset after that. If that don't help please contact your seller to exchange the device. Sorry for this inconvenience. (Only) if you don't receive help by the seller please contact us with all your buying details (shop, date, order-number, ...).
