Simple Flashing Tutorial
Thu Jun 15, 2017 11:30 am
In the PDF file below is a simple flashing tutorial for BV6000.
Before you start flashing, please make sure you have understand clearly about this operation and you can do it.
flashing-BV6000_v4.pdf
(363.74 KiB) Downloaded 13623 times
97gérard216
Re: Simple Flashing Tutorial
Fri Jun 16, 2017 10:43 am
Hello admin,
Links for windows 10 32 or 64 bits
Drivers
https://tehnotone.com/windows-10-mtk-vc ... -tutorial/
SP Flash Tool
http://spflashtools.com/category/windows
Mon Jun 19, 2017 8:11 am
97gérard216 wrote:
Hello admin,
Thank you! I inserted your link for “Driver Signature Verification” in our version. Everything else should be the same.
97gérard216
Mon Jun 19, 2017 9:03 am
Thank you
Gummidichtung
Thu Jun 22, 2017 6:59 pm
I have bought a new BV6000 for my wife.
My own BV6000 updates perfectly over OTA, so I never needed to flash.
The new one does not, so I have to flash it.
Going throuth the tutorial, after installed the drivers, enabling flash tool to do its work with downloaded Rom, what exactly should happen after done point 7) (connecting off phone with PC by USB)?
At me Flash tool is doing nothing, phone shows battery loading status and thats it.
Should happen something different?
If yes, what?
Thanks and Best regards
G.
Tue Jun 27, 2017 11:18 am
@Gummidichtung The flashing process should start at that point if you pressed "download" and the turned off phone get connected to the pc. The white bar at the bottom of the screenshot is getting colored and filled with status information.
If that don't happened it seems the driver is not installed correctly. Please install this driver: http://www.devfiles.co/download/0InO9P5 ... RIVERS.zip
Aphexx
Sun Jul 09, 2017 11:47 pm
Hey there!
I flashed my BV6000 after a Bootloop tonight using the 20160608 ROM. Everything worked out fine but now my phone won't start anymore. Screen remains black, the computer won't detect the device anymore. Please help me!
Wed Jul 19, 2017 10:01 am
Aphexx wrote:
Hey there!
Please try to reflash it. Maybe use an newer ROM for that.
MP021013
Sun Aug 06, 2017 1:32 am
Hi
Could it be possible to have a simple flashing tutorial for linux please !
Bests regards
A Linux Debian's User (Debian 8 Jessie)
Tue Aug 08, 2017 2:18 pm
MP021013 wrote:
Hi
Bests regards
Try this one: https://forum.xda-developers.com/genera ... x-t3160802
