m.gonschorek
Bluetooth smart (Bluetooth low energy) connection fails
Tue Jun 13, 2017 2:48 pm
Is there any update, wich fixs up problems with Bluwtooth low energy (Blutooth smart) connections?
My BLE-heartrate belt is shown in the list of connectable devices, but the phone dosen't connect to it if I try.
Since my last updat to Android Nougat, every BT-connection takes more time. In most cases i need a few tries to connect a BT-device.
My current Software Version is; BV6000_Blackview_V01_20161216
Thanks for your help.
Parcheval
Re: Bluetooth smart (Bluetooth low energy) connection fails
Wed Jun 14, 2017 3:18 pm
Try to upgrade to a new rom:
viewtopic.php?f=144&t=101183&start=40
m.gonschorek
Thu Jun 15, 2017 2:21 pm
Done.
Problem solved.
But now I got a laggy home-button and a laggy Back-button :roll:
Fri Jun 16, 2017 8:33 am
I hope this will be fixed in the next version.
Here is a workaround if you like: viewtopic.php?f=142&t=132163
m.gonschorek
Mon Jun 19, 2017 8:17 am
I am verry sad, the old BT-Problem is back again. It worked just two days. Can I somehow reset the Bluetooth settings? The BLE-device is shown in the list of connectable devices, but if try to connect --> "Communication with Bluetoothdevice is not possible".
Thanks for any help!
Mon Jun 19, 2017 8:55 am
We have reported your issue and we are studying it, if any solution, we will be back soon.
