ipoluhin
the main microphone does not work
Tue Jun 13, 2017 2:09 pm
Hello.
For incoming and outgoing calls, the main microphone does not work. That is, I hear the interlocutor, but he does not exist. It also does not work for voice search.
The microphone works in hands-free mode and with audio or video recording.
In what there can be a reason and how to solve this problem? Thank you!
ipoluhin
Re: the main microphone does not work
Tue Jun 13, 2017 9:29 pm
The problem is not critical. But very uncomfortable - you always need to keep a headset nearby :(
Marino
Tue Jun 13, 2017 9:37 pm
P2lite problemi microfono non si sente si può avere aggiornamento firmware
Dongermon
Tue Jun 13, 2017 10:11 pm
ipoluhin wrote:
Hello.
What build number?
when did this occur?
Did you do anything beforehand that might have cause this issue?
ipoluhin
Wed Jun 14, 2017 4:45 am
I found the problem right after receiving the device - at the first call.
Build number P2_Blackview_20170307 - the last official.
Re-flashing the same assembly did not fix the problem
Wed Jun 14, 2017 7:39 am
Hello, for the microphone problem, please contact the online reseller to get repaired or replacement.
ipoluhin
Wed Jun 14, 2017 4:40 pm
Someone met with this problem. Someone did not meet. What is the reason for this? Can a replacement board with a microphone help?
ipoluhin
Sat Jun 17, 2017 5:24 am
Wed Jun 21, 2017 6:29 am
"Start the phone into recovery:
- Press Power and Volume up together for around 10 Seconds
- When the open android is shown press Power and Volume up together again
- After factory reset select ""reboot system now"""
If still can not fix it, please let us know.
ipoluhin
Sat Jun 24, 2017 9:52 am
Hello.
Did everything as recommended. The microphone is not earned
