Flash rom P2 lite_Blackview_201706071002
Mon Jun 12, 2017 9:25 am
Flash rom P2 lite_Blackview_201706071002 to optimize the telephone receiver.
https://mega.nz/#!JfoRWT5Z!QhgjX63Ytr4N ... BpYEKcqUp0
blackview flash guide.docx
(368 KiB) Downloaded 1395 times
deveci08
Re: Flash rom P2 lite_Blackview_201706071002
Tue Jun 13, 2017 7:31 am
https://mega.nz/#!tKxHkQAZ!bBoMAh2aDqwd ... NOKCBIjkvc
I can't figure out the wifi error with this update
Can you update WiFi fix.
Wed Jun 14, 2017 5:47 am
Can you please tell exactly the wifi problem?
deveci08
Thu Jun 15, 2017 11:51 am
when I connect to wifi. the phone restarting constantly
don't connection to a WiFi network, it's okay. but connect to Wifi, the phone constantly restarting
Dongermon
Thu Jun 15, 2017 7:35 pm
Did you flash the update
deveci08
Thu Jun 15, 2017 9:14 pm
of course, I did
Dongermon
Thu Jun 15, 2017 9:48 pm
of course, I did
try uninstalling any apps that you have installed just before you started having this problem
if that doesn't work try disabling google play services
deveci08
Fri Jun 16, 2017 4:17 pm
reset the phone. I disabled Google Play services. it didn't work. is rebooting constantly when connected to WiFi.
a video about the problem of the phone.
https://www.youtube.com/watch?v=GbePi3Eixzc
Dongermon
Fri Jun 16, 2017 7:23 pm
video is broken, do you happen to have any amazon apps installed
deveci08
Fri Jun 16, 2017 8:35 pm
anything else outside of ROM applications is not installed.
this problem is not sourced from any application.
sourced from the original ROM. this update is required for wifi fix. one possibility is that there may be a malfunction on the motherboard. the motherboard is very bad. because I can't get. the seller was unreliable. can't send the necessary parts under the manufacturer's warranty. because I can't get. I'm sad and angry because I bought the wrong phone.
