mTnY
Root Access
Wed Dec 16, 2015 8:03 am
I'm looking for a way to Root my phone.
It have very weak vibration and by root it i will able to make it stronger.
Do anyone have a way to root it?
Re: Root Access
Thu Dec 17, 2015 9:42 am
Hi ,
BV 5000 Can not use root , and if you use our Flash Tool We publish ,
no need to root !
Best regards,
Admin
mTnY
Re: Root Access
Thu Dec 17, 2015 1:30 pm
But I must to have root access so i will able to change the vibration strenght.
nyfd_it
Re: Root Access
Thu Dec 17, 2015 2:09 pm
A bit of confusion dear Admin: flashing is one thing, rooting is another.
What the user is asking is how to root the phone to have the permission to change same parameters like the intensiy of the vibration and others.
The flashing tool is used to update the rom of the phone, but it doesn't generate root permissions.
dave136
Re: Root Access
Thu Dec 17, 2015 7:25 pm
go to viewtopic.php?f=93&t=961 instal ZIP
mTnY
Re: Root Access
Sat Dec 19, 2015 6:31 pm
I tried it, and got error in the update screen .
(i copied it to micro sd card then install it from Wireless update -> local update...
What can i do now?
