ipoluhin
The problem with the microphone
Sat Jun 10, 2017 8:47 pm
Hello!
From the very beginning during calls is not working the main microphone. Noise reduction turned off. A factory data reset did. It did not help.
Also the microphone does not work with voice search. Works only when the audio / video recording and speakerphone.
What it can be connected and how to fix it? I'm not the only one with this problem.
Re: The problem with the microphone
Wed Jun 14, 2017 7:54 am
Can be fixed by either an update or flashing the ROM again.
