telmoalmeida
BV7000Pro not Google certified ?
Sat Jun 10, 2017 11:04 am
I buy one BV7000Pro few days ago and i notice that is not yet Google certified.
Due that is not possible for me to install some app from my company due security policy.
The previous version BV7000 is already certified, when is planned to get that also
for BV7000Pro ?
Thanks
Re: BV7000Pro not Google certified ?
Wed Jun 14, 2017 10:07 am
BV7000pro already got google certificated
telmoalmeida
Tue Jun 20, 2017 7:40 am
Ok, but when i check in Google Store app settings, under Device certification i still have the indicating Uncertified, how can i get rid of this ?
Wed Jun 21, 2017 8:05 am
Thanks for your feedback. I will recheck this.
geotex
Wed Jun 21, 2017 8:10 am
Me too. Device Uncertified. Even Blackview not appear in Google store
Thu Jun 22, 2017 10:01 am
(The BV7000 is the first Blackview device on your list screenshot.)
But we now also plan to publish a new ROM in which the certification status in play store is correct.
Thu Jun 22, 2017 10:41 am
Marco-66 wrote:
Thanks, I've seen it in the list OF COURSE ... since the BV7000 pro is not certified, I assume that there are two different devices at the certification level, the BV7000 and the BV7000 pro .... otherwise how can you explain the current situation? Another bug in the firmware ?
I don't know why there is only one entry for both versions.
We plan to publish a new ROM in which the certification status in bv7000 pro's play store is correct.
