Flash manual for BV7000 Pro
Fri Jun 09, 2017 2:52 am
Below is the flashing manual for BV7000Pro, before you start flashing, please make sure you have known clearly about this operation and you can do it.
flashing-BV7000pro_v4.pdf
(373.65 KiB) Downloaded 10834 times
Holefighter
Re: Flash manual for BV7000 Pro
Fri Jun 09, 2017 4:52 am
Thanks for this manual, now we only need the Android 7 /7.1 file :-)
Heo Quay
Sat Jun 17, 2017 7:02 pm
After 3 weeks owning the BV7000pro. Is it possible to reflash a DEAD phone? It got to 35% battery and shit itself...
Any help from Blackview would be helpful.................
Heo Quay
Sat Jun 17, 2017 7:04 pm
What pisses me off the most, is this phone has so much potential....It was a great phone, for3 weeks
Dongermon
Sat Jun 17, 2017 8:00 pm
yes you can use sp flash tool when the phone is off to reflash a rom onto your device as it connects using the vcom drivers, which are constantly running
Mon Jun 19, 2017 8:41 am
Yes, you can use the same tutorial for a bricked phone or for solving other problems.
geotex
Thu Jun 22, 2017 11:34 am
I follow the tutorial step by step , but after 10 minute I have BROMERROR in SP Flash All is fine, include VCOM drivers. Maybe this error is possible to appear because the phone is encrypted(Android system)? Or before start flashing is good to make a factory reset?
Thu Jun 22, 2017 12:01 pm
For normal you need no factory reset before flashing and also encrypted phones was no problem in my test. Was this your error message?
Message: BROM ERROR S_DL_GET_DRAM_SETTINGS_FAIL (5054)
Meaning: The files you're trying to flash do not belong to or are not compatible with the phone you're trying to flash them to
Solution: Ensure you're using the correct files. If you're sure they are, then try formatting before flashing again. (By Formating you may loose your IMEI. It can be complicated to restore it by SN write tool.)
geotex
Thu Jun 22, 2017 12:26 pm
The message is BROM ERROR: STATUS_DEVICE_CTRL_EXCEPTION(0xC0050001)
geotex
Thu Jun 22, 2017 12:28 pm
And the file is from this forum - BV7000_PRO_Blackview_20170523-
