mobosenshi
Screen Cracked
Fri Jun 09, 2017 12:47 am
Today my BV6000's screen cracked. I accidentally dropped it on the sidewalk :cry: I contacted the reseller, geekbuying, for repairs :mrgreen:
I really thought that this phone was virtually indestructible....
Dongermon
Re: Screen Cracked
Fri Jun 09, 2017 1:09 am
the screen is made out of corning gorilla glass 3, sturdy but not indestructible
mobosenshi
Re: Screen Cracked
Fri Jun 09, 2017 1:32 am
I've seen this phone being drop from buildings and seen it take a beating too :lol:
Watch:
Toughness Test on BV6000 Touch Screen May 12th 2016
https://www.youtube.com/watch?v=UZDDGG0ehaw
BV6000s is just as tough as BV6000, Bumping Test
https://www.youtube.com/watch?v=bPmHR8z_vwg
This is how tough Blackview BV6000 is June 18th 2016
https://www.youtube.com/watch?v=vffAy9kMliY
Re: Screen Cracked
Fri Jun 09, 2017 2:01 am
Yes, sturdy but not indestructible.
You can purchase a new screen from aliexpress and replace this destroyed one.
https://it.aliexpress.com/wholesale?cat ... 000+screen
mobosenshi
Re: Screen Cracked
Fri Jun 09, 2017 2:21 am
Does this mean that BV via geekbuying won't repair it?
If not, am I purchasing just the Touch Screen Digitizer?
bvbw
Re: Screen Cracked
Fri Jun 09, 2017 5:58 am
I have changed the screen some weeks ago ...
You have to buy the complete front panel (take care with the color)
mobosenshi
Re: Screen Cracked
Sat Jun 10, 2017 10:00 am
Was it easy? I need instructions. Did you watch the teardown video?
bvbw
Re: Screen Cracked
Sat Jun 10, 2017 12:13 pm
Yes, it was.
The video is a good help and you have to follow it step by step.
No obligation with the soldering procedure : you can use the part directly if keeping the entire part (microphone) with silicon attached (see video)
HelloWorld
Re: Screen Cracked
Sun Jun 11, 2017 7:21 am
Replacing the screen is easy, replacing only the digitizer is nearly impossible unless very skilled. Better to spend a few €€ extra to avoid frustration/failure.
Parcheval
Re: Screen Cracked
Wed Jun 14, 2017 3:15 pm
Same as already discussed here: viewtopic.php?f=142&t=116161
