Pette
Last update ROM on BV6000_Blackview_V01_20170517 The phone is nothing.
Tue Jun 06, 2017 6:09 pm
I updated the ROM via OTO, I can not make calls because the calls are interrupted after 1-3 minutes.
I need to return to the earlier version of ROM. Can you write a return procedure?
Otherwise, the phone is on disposal.
Re: Last update ROM on BV6000_Blackview_V01_20170517 The phone is nothing.
Thu Jun 08, 2017 6:51 pm
you could flash your phone over pc.
Here is a tutorial: viewtopic.php?f=144&t=54240
Pette
Thu Jun 15, 2017 8:48 pm
Everything went according to your instructions. The result is bad. The phone is already dead after uploading the new system (by Sp Flash Tool). It can not be turned on and no buttons are responding. My Phone is 6 months old. I have no phone since I started last update ROM BV6000 _Blackview_V01_20170517 via OTO.
Unfortunately, I do not know what to do now.
Fri Jun 16, 2017 8:30 am
Reflashing is the only solution if you bricked your device. Be shure to understand and follow the instructions.
Sat Jun 17, 2017 6:47 am
We reported this issue, hope can find ways to help you.
Dongermon
Sat Jun 17, 2017 1:23 pm
you do not need the phone to be powered on, sp flash tool connects directly to the phones most basic driver (mtk usb vcom)
try following this guide
https://devs-lab.com/how-to-unbrick-med ... evice.html
Pette
Sat Jun 17, 2017 6:48 pm
For information I give:
The computer does not know, when connected to the phone.
The PC responds to the phone only after pressing the FTT button and then installs the driver - MTK USB port (com4)
Is there some way to communicate via VCOM ? :?:
Otherwise, the phone is completely dead.
Pette
Sat Jul 08, 2017 2:00 pm
Nothing resolved
I have used your OTO update - then interrupted calls.
I have done according to your instructions to update the older version.
Result: Phone is dead (nothing works)
Your link to the manual is not working (can not connect).
The conclusion is:
- you are not able to know, what to do
- your OTO update has brought the whole problem
The BV6000 is nothing. Telephone probably should be discarded.
You are still able to cope ? - no broken link
Mobile phones blackview = great disappointment. I thought I would have a good brand of mobile for the future as well. Unfortunately, no. :cry:
Pette
Sun Jul 09, 2017 11:34 am
After uploading the firmware 20170517_s12v55_jk_3m, the BV6000 communicates, but the system does not start. The display switches on with the Blackview inscription. I'm sending a memory test.
Memory test
Memory test.JPG (121.22 KiB) Viewed 4876 times
Pette
Sun Jul 09, 2017 12:12 pm
Final status after startup
Final status after startup.jpg (36.81 KiB) Viewed 4865 times
