Patrik3000
My BV is turning of it self
Tue Jun 06, 2017 4:05 am
Hi my Bv 7000 pro is turning of itself when the battery is lower then 90% . i have to restart it and then i have to set the clock and the date. What shall i do? I have only used it for 2 weeks. And when im shaking the phone it feels like something big is loose inside.
Re: My BV is turning of it self
Fri Jun 09, 2017 12:15 pm
that sounds like your battery connection is bad. You could ask your seller for free exchange or let it fix in a local mobile repair store fast and easily.
cientistagyn
Sat Jun 10, 2017 7:07 pm
If i disassemble the bv7000 pro to fix baterry or any button, does it lose the ip68 water proof seal ?
Mon Jun 12, 2017 5:52 am
Hope the below video can help you to disassemble the device.
https://www.youtube.com/watch?v=ISSev8V ... e=youtu.be
Thu Jun 22, 2017 10:38 am
No, if you do everything like shown in the video and don't forget to mount any seal the waterproof will stay.
