misasu89@gmail.com
frecuencia en bandas mexico
Mon Jun 05, 2017 11:05 pm
Buy a few days ago a bv7000 pro but it has been a nightmare since the calls are cut off and the internet is dead in none of the options (2g, 3g and 4g), a technician tells me that the problem is with the band frequencies Used in Mexico that do not match the ones that the phone brings please could help me as I can use this wonderful phone.
Re: frecuencia en bandas mexico
Fri Jun 09, 2017 12:17 pm
If your local carrier frequencies are not fitting to the phones frequencies you can not use it for mobile connection. Please check frequencies before you buy.
