bvbw
GPS time is wrong (workaround found)
Sun Jun 04, 2017 2:53 pm
blackview_admin,
Please,
it's necessary to fix the GPS problem (time -1h00) in next update version for BV6000 nougat.
Currently, it's very annoying with many GPS apps ... :evil:
Thanks
bvbw
Re: GPS time is wrong
Tue Jun 06, 2017 4:20 am
blackview_admin,
can you tell something about this problem ... or not ... ???
Dongermon
Tue Jun 06, 2017 6:06 am
bvbw wrote:
blackview_admin,
have you tried a factory reset? or downgrading to an earlier rom?
bvbw
Tue Jun 06, 2017 6:29 am
I'm not ready to do factory reset (too many things lost) ...
Previous versions have many other bugs also, reason why i would prefer OTA update or local update !
Dongermon
Tue Jun 06, 2017 6:47 am
Have you got any knowledge on ADB?
Tue Jun 06, 2017 6:50 am
This is something about the system time in your phone and the server time in your GPS app.
If the GPS time doesn't sync the system time, the gps time will be wrong.
You can try to set the gps time to sync your phone time.
But most of the apps will automatically sync the phone time.
bvbw
Tue Jun 06, 2017 7:04 am
My phone time is OK.
Some GPS apps show the time one hour less (problem)
I just want to fix the GPS time ... (it's a recent problem maybe because last version)
Tue Jun 06, 2017 7:34 am
Please try to set the gps time to sync the time in your phone.
bvbw
Tue Jun 06, 2017 7:35 am
how ? In settings i set hour to GPS time but there is no action on GPS time in apps (only action on phone time what i don't want)
Tue Jun 06, 2017 9:27 am
Hello, we checked, can not set to sync, the only can do is to uninstall your current gps app, and download and install another gps app which it's time is syncing the phone time.
Not only our phones, other Brand phones also have this problem, the key problem is about the gps app.
