christiansenn
Old V01_20161011 how to upgrade latest android7 stable?
Sat Jun 03, 2017 10:20 pm
What are steps to get latest android 7 without bricking or any other issues?
Right now it runs fine the phone no major issues.
Re: Old V01_20161011 how to upgrade latest android7 stable?
Tue Jun 06, 2017 8:23 am
First you should update your phone's rom one by one.
Please follow the below steps:
1. Keep the wifi open
2. Setttings--about phone--wireless update---check for updates
Untill you upgrade to the latest version, tell us your latest version no. and we will send you the download flash rom to upgrade Android 7.0.
christiansenn
Tue Jun 06, 2017 7:02 pm
Hi
I already run phone update
but it says it is up to date even it is old Android 6 1011
Before upgrading to android 7 can i save all settings/apps etc
so it dont get wiped?
christiansenn
Tue Jun 06, 2017 8:56 pm
It says bv6000_black_view_V01_20161011
And no updates.
Can you enable OTA for it?
yoyotogo
Wed Jun 07, 2017 10:25 am
I confirm , No OTA available for this version
(i'm in TOGO , west Africa)
christiansenn
Wed Jun 07, 2017 10:31 am
What is step by step to upgrade it?
christiansenn
Wed Jun 07, 2017 10:45 am
I download 1025 from https://mega.nz/#!ewE0WAzD!Xoesxmywc6AA ... YEz4EUHFNc
Now what is the best way to flash it?
Here are all latest ROM files: viewtopic.php?f=144&t=101183#p284253
You can try a local file update (menu in OTA update checker) or flash it over a computer.
christiansenn
Wed Jun 07, 2017 10:52 am
Can I go from 1011 version to latest may version
or must go 1025 first?
Dongermon
Wed Jun 07, 2017 11:13 am
You can go straight to the latest, it won't harm your device in any way.
Flashing solutions can be either local update on your phone, or via pc, if local update does not work follow my guide
viewtopic.php?f=172&t=130585
