ekptr
BV6000 Micro USB cable
Sat Jun 03, 2017 4:38 pm
It is safe to use another cable to charge the BV6000?
Is anyone have a trouble while charging, after the original BV6000 USB cable had to connected to the other phone?
I had a problem in charging because my friend accidentally connect my original bv6000 usb cable to other phone, it seems made the micro usb port broken
Re: BV6000 Micro USB cable
Thu Jun 08, 2017 3:34 pm
There should be no damage if the longer plug are not inserted with force.
bvbw
Tue Jul 11, 2017 7:44 pm
For people who want to use any standard cable on BV6000 : this is a small adaptator (long pins 9 mm) easy to use anywhere ...
https://fr.aliexpress.com/item/2pcs-9mm ... 4.2.CZn1J7
yoyotogo
Mon Aug 07, 2017 8:20 am
frofa
Thu Nov 02, 2017 2:29 pm
good to know, thanks!
