Flash ROM of BV7000_PRO_Blackview_20170523
Fri Jun 02, 2017 10:01 am
Flash ROM of BV7000_PRO_Blackview_20170523 in the below link
https://mega.nz/#!ZfhiyQrY!cqyjq5ODBhX- ... stKfVa6PBc
Holefighter
Re: Flash ROM of BV7000_PRO_Blackview_20170523
Fri Jun 02, 2017 1:14 pm
Is it also avadible via ota?
Holefighter
Do you habe a changelog?
Zeerch
Sat Jun 03, 2017 8:44 am
So.... Has anyone tried to upgrade to this firmware?
I tried OTA and its not there yet, I have it downloaded but I dont want to try to update unless I know what its about or have a older version
I current have a spare phone with 20170411 running, so anyone have this for download?
Admin- Would you please be kind enough to tell us if this is Android 6 or 7? and what are the fixes, Many of us have broken phones because of the last firmware you released to the public. So would you please be kind enough to tell us what is new about this and what it fixes?
Holefighter
Sun Jun 04, 2017 2:01 pm
Same issue
Dongermon
Sun Jun 04, 2017 3:56 pm
Holefighter wrote:
Same issue
you dont update it via OTA, either flash it by my guide or use the local updates option
Holefighter
Sun Jun 04, 2017 7:25 pm
Marco-66 wrote:
Dongermon wrote:
Holefighter wrote:
Same issue
Why not???????
Holefighter
Sun Jun 04, 2017 7:48 pm
EDIT : I have renamed it to zip and the upgrade has been started ; be aware that, at least in my case, the screen was completly black for some minutes ...
At the end I have checked the firmware version .... but it is still the old one .... suggestions ?
Same Here......
Paulli
Sun Jun 04, 2017 11:14 pm
Hi !
I have upgraded my BV7000 Pro to this version, it has not fixed my A2DP Bluetooth problems.
I might add something to the guide : if you are on Windows 10, the driver installation is not really straightforward. There is a tutorial here : https://forum.xda-developers.com/elepho ... 4-t3267033
Furthermore, I haven't add to push any buttons on my phone to install the firmware : shut it down, connect the cable at the phone end, hit "download" on the software and only then connect it the pc end. It enabled me to recover a soft-bricked phone ( I had interrupted the process during to deselect userdata but the phone would not boot after completion.)
Beware that this will completely wipe your phone as I wasn't able to flash it conserving the userdata partition.
Here's hoping Android 7 will come soon.
jdcesari
Sun Jun 04, 2017 11:36 pm
If you have problems in bluetooth connected to speaker or car audio, install the app
Bluetooth file transfer
It improves my connection
It worked for me
