karera
BV7000 Pro battery and overheating
Thu Jun 01, 2017 4:28 pm
The time I used it for the first time the phone os overheating and drain fast like when I'm playing Shadow Fight 2 for 30 mins the battery reduces more or less 10% and it's overheating and it burns also when it's charging.
Re: BV7000 Pro battery and overheating
Fri Jun 02, 2017 5:54 am
Can you please tell your phone's build no?
And please send us your burning picture?
Fri Jun 02, 2017 5:57 am
When charging, you'd better turn off the game and the video.
karera
Fri Jun 02, 2017 11:14 am
Build No.: BV7000_PRO_Blackview_20170523
When I said "it burns" I mean it hot. The metal(-like) part of the phone where the camera and fingerprint sensor is attached.
Dongermon
Mon Jun 05, 2017 9:38 pm
It heats up in that area because that is where the cpu and gpu chip is situated, if its a heavy load it will heat up, as for charging it is using a usb type c at 5v 2a which means its delivering charge faster, electricity transfers heat, there is nothing to fear.
