nesterov32
Firmware P2 lite: Exchanged microphones
Thu Jun 01, 2017 1:50 pm
Hey. When will a new, flawless firmware be released that fixes all the bugs described here? As a bug application-phone, errors with microphones (conversational and noise reduction).
People buy your phones, so please kindly correct the software mistakes that are made during the use of the phone. All the same, phones are not cheap, and I would like something to react faster and more fruitfully.
Re: Firmware P2 lite
Wed Jun 07, 2017 6:52 am
Do you mean the microphone or loudspeaker be noise?
ococ
Wed Jun 07, 2017 7:24 am
Microphones do not work properly. The microphone near the camera works like the main one. The microphone at the bottom of the phone works like a noise canceling device. Microphones are not properly programmed.
nesterov32
Wed Jun 07, 2017 1:53 pm
Are you kidding or dumb really? Or do not know where the microphone is in the phone, the spoken one is located? The phone has a problem with microphones, make the firmware fix it! The microphone which is located below has a low sensitivity and the interlocutor does not hear me well! And if you talk to the top, then it hears well! But it's not right!
Rubin_83
Thu Jun 08, 2017 8:24 am
Ребята, киньте пожалуйста БЕКАП прошивки!!!!!!!! Очень нужно...!!!!!!!!!!!!!
Wed Jun 14, 2017 6:31 am
Hello everyone, for the microphone problem, please contact the online re-seller to get repaired or replacement.
virussidac
Mon Jul 24, 2017 2:37 pm
microfono non funziona bene.mi sentono cupo e male.
arrivato a casa con android 7.in attesa di un loro aggiornamento.
provate a disattivare nelle impostazioni dell app di google,nella sezione VOCE,tutte le spunte su OFF.provate.
Wed Aug 02, 2017 9:57 am
please try to write in english here or at least translate with google translate
Re: Firmware P2 lite: Exchanged microphones
Wed Aug 02, 2017 10:26 am
Some users reported last firmware update solved the microphone issue.
Fri Aug 04, 2017 9:25 am
If you are affected by this issue of changed microphones connection please try to update to the latest firmware and perform a factory reset after that. If that don't help please contact your seller to exchange the device. Sorry for this inconvenience. (Only) if you don't receive help by the seller please contact us with all your buying details (shop, date, order-number, ...).
