wheelermanfr
pb battery
Wed May 31, 2017 8:01 pm
Hello
I bought about 1 month ago a BV7000 Pro and it no longer works: Does not turn on and does not charge (no notification Led)
After bringing it to a repairman, he told me that in fact it is the wire that connects the battery to the card that is cut and it is certainly due to the manufacture because it is to the Where the wire makes a curvature so the battery is HS.
If you wish, I have a photo that attests it.
Could you explain how the warranty works?
Waiting for an answer from you.
cordially
Re: pb battery
Thu Jun 01, 2017 10:00 am
In this case, you can contact the online re-seller to get replacement or repaired.
