wheelermanfr
bv7000 Pro Cut wire battery
Tue May 30, 2017 6:55 pm
Hello
I bought about 1 month ago a BV7000 Pro and it no longer works: Does not turn on and does not charge (no notification Led)
After bringing it to a repairman, he told me that in fact it is the wire that connects the battery to the card that is cut and it is certainly due to the manufacture because it is to the Where the wire makes a curvature so the battery is HS.
If you wish, I have a photo that attests it.
Could you explain how the warranty works?
Waiting for an answer from you.
cordially
Model: BV7000 Pro
Re: bv7000 Pro Cut wire battery
Fri Jul 07, 2017 2:55 am
Can you please send us the picture?
