Dongermon
Flashing guide
Sun May 28, 2017 8:19 pm
Hey guys, completed the sp flash tool guide for you all, wasn't sure about including a twrp tutorial as it may void warranties.
If anybody has any problem at all, you can contact me on skype- live:brett.council.97
blackview guide.docx
(417.23 KiB) Downloaded 2582 times
Grundkurs
Re: Flashing guide
Tue May 30, 2017 5:21 pm
i was able to install the firmware 17_03_2017 following your explanation, thanks a lot!
First i got stuck: When pressing download the red bar appeared but it didnt change to yellow and canceled with an error-meesage. Then i changed the USB-Port and tried it again, then it worked.
Dongermon
Re: Flashing guide
Thu Jun 01, 2017 9:40 pm
Glad I could be of service!
Re: Flashing guide
Fri Jun 02, 2017 6:28 am
Thank you, Dongermon.
Holefighter
Re: Flashing guide
Thu Jun 08, 2017 7:02 am
i try the instructions but it always say This device cannot start. (Code 10)
What can i do. I have Windows 7 ultimate 64bit.
i try to install the driver like this http://techprolonged.com/2015/03/instal ... ndows-all/
Dongermon
Re: Flashing guide
Thu Jun 08, 2017 9:00 pm
this can be caused by previous drivers that have been installed such as samsung kies. You can use http://www.nirsoft.net/utils/usb_devices_view.html
to look at all installed drivers and uninstall previous ADB and fastboot etc. drivers. then when you plug in your phone go to device manager find your phone in the list, right click and install drivers by browsing a list.
