mikseven
BV7000 Pro - Android Users
Tue May 23, 2017 5:51 pm
Hi to all, I'm an happy user of a brand new BV7000 Pro.
The device works very well, except for a missing feature, Android Multiple Users.
I used this feature on many devices with Lollipop, MarshMallow and Nougat. It's Very important for me due to work needs.
Do you know if there's a procedure to enable this feature?
I see the User icon in the Drop-Down menu, but tapping on it return this message "The contact doesn't exists"
Many thanks
Re: BV7000 Pro - Android Users
Fri Jun 02, 2017 5:38 am
Can you please tell more about the Android Multiple users?
johni indo
Fri Jun 02, 2017 8:55 am
there is small icon on top right screen, if we tap, we can change it with other users or guest with different setting
mikseven
Mon Jun 05, 2017 5:37 pm
Exactly, but if I click on it, i got "The contact doesn't exists".
Mon Jun 19, 2017 1:16 pm
Had you set the new user under "settings>users>add user" before?
